Is it really 4.0 Qts, or is that a misprint in the online Owner’s Manual? It’s my father’s 3.5L. I was looking at it recently for another problem and in the midst of that pulled the dipstick (3 times) to see the oil level above the 4-dimples/cross-hatch area! I did the last oil change on it in December (car’s only been 900 miles since), and I’m thinking maybe I put 4.5 qts in it because that’s what I’ve been putting in my 2002 3.4L Impala for 18 years now (don’t remember checking the owner’s manual ... but maybe I did ... 4.0 qts seems odd to me now).
The “other problem” was a reported leak onto my sister’s driveway. The car was driven 20 miles and parked, allegedly leaking all over her driveway. I just idled the car (on ramps) for 20+ minutes, watching the fans cycle 2-3 times, and didn’t see any fluids dripping anywhere ... but there is a glistening on the bottom of the oil pan and signs of a possible coolant leak - but not from the intake gaskets or water pump ... all dry there. The plastic coolant tank looks low and the color is dark ... like oil. As it idled you could see some fluid coming back in but it barely covered the bottom of the tank! Maybe oil mixing with coolant??
I’m thinking coolant flush and oil change (using 4 qts, I guess), then watching to see what it does next. Car only has 85,000 miles on it and it’s clean and dry under the hood just about everywhere you look! The only “smoking gun” is the glistening on the under surface of the oil pan, tracing back upward where the passenger-side motor mount is, maybe some on the A/C compressor, and one of those black “accordion-style” plastic tubes covering a wire(s) that’s loops around the bottom (which I think is what actually transfers the leak around to the bottom of the oil pan).
But the water pump is clean and dry, and it didn’t leak out after I turned the engine off ... nor did I hear any gurgling noises or really smell any coolant after the engine was off.
Could a 1/2 quart overfill cause oil to be forced into the coolant?
Oh - the other strange thing was ... the spotting on the driveway was several inch or greater diameter blotches in an area about 3 feet in diameter ... even though the car was parked and never moved! That makes no sense to me...
