ahhh-HA! .....ok, .....thanks a BUNCH for THAT info! ANY INFO....lol. Cold weather right around the corner...didn't make alot of progress over the weekend really. I'm going to take a shot at responding to what you said Bruce ....as sensibly as I can. Please bear with me. Soooo.......(warning - my mind is a bit tangled up with the terminology - and ok ...also how the circuit works on my car in particular - 2010 - since the design seems to vary on other years best I can tell)! Terminology check...when you say 'hvac control module' is that the same as the blower motor resistor module (speed controller)? .....and when you say 'blower motor module' (powered thru Batt 4) ....I'm not sure specifically what you mean. Yes - I am not a master mechanic .....barely an amateur. But do have history believe it or not ...in electronics. Ok ....years and years ago. ....but I do still fix things these days.....lolol.
.....thoughts....that may not make sense at all....but have to ask..... Sooooo - the BATT 4 could have blown ...causing blower to not blow at all now....correct? ..maybe??? (I did test the motor - grabbed 12vc off of the resistor module input connect (2 of the 5 pins have 12v ....(not the 2 of those 5 that go to the motor) .. I was able to power the 'disconnected' (and uninstalled actually) blower motor from those 2 pins I mentioned with the 12v. The motor about flew out of the car. It worked. ( yet another video showed me how to do that) ..... Ok, ....feeling the need to mention .....(sorry girls) I am a GIRL. lolol. Annnnd a grandma no less. A rocking grandma ...thank you very much.....lol. Ok ...back to the the point...and I do have one...... 'Yes the motor stayed on with car 'off''. ....a sign of a bad resistor...I guess. BUT ....one of the 200 videos I watched ...mentioned that 'high speed' is ran directly from the battery. (didn't mention if a 'fuse' was along the way - which would stand to reason of course) .......... I figure I definitely have a bad resistor .....and maybe a bad fuse. The dang fuse cap with the fuse layout (for under hood) ....did not say 'hey lady....this is the blower fuse...relay..... There was a 'bcm' fuse - which I erroneously figured was the blower control module - ....ha .....not the 'body control module'. (Ok ....maybe I do need to retire....but No ...not gonna quit here.....lol!) .......I saw ....in one of the videos ....of course....I swear - (Bill) ...they mentioned the relay in the blower control resistor module, ......but .....heck..... my brains are taking some heat....so ....yes I could be w-w-w-w-wrong.
Sorry for the lady chattiness........ To the point.....I'm guessing that BATT 4 fuse may be shot? I'll check it. Maybe swap with a matching one? (assuming I don't disable some other important link in the chain for that test). I'll figure that out - I know - run to the store and get one.
.....simply put - (Surprise!) .....once I get the wicked resistor module (with the stripped screw underneath the passenger dash - in about 3 inches of working area.......And get those friggin plastic beast pegs out of it .......(or just pry it animal style to get it off) ......I can replace the BATT 4 fuse ...if necessary ........and be ready for cold weather (day after tomorrow......lolol) ......I have a big God .....soooooo.......He'll be comin thru very soon I'm sure. Already chimed in - through you guys. thanks so much for reading my technical novel.....jeeeeeez!
