Hey guys,
So I have a 2010 3.5L engine code N. I'm getting "Reduced Engine Power", and codes P0335 (Crank Shaft Position Sensor) and P0651 (B circuit). Yesterday I could start the car, it had reduced engine power. I replaced the throttle body (and TPS) and today the car wont even start. I know the Accelerator PS, TPS, and Crank Shaft sensor are all on the B circuit. The APS was replaced at the dealership 4 years ago, so it should still be good. I'm getting the crankshaft position sensor tomorrow. What else could be causing these problems? Any ideas? If it helps; car was running fine until I spun my tires trying to get out of snow snow, drive find the rest of the day but the following day, while driving, I got reduced engine power and service stabilitrak and limped back home. The service stabilitrak message has gone away but I'm still getting the other symptoms. Please help, I'm from NC and now stuck up in WA without a car and don't have any connections up here.
