Recently I got a 09’ Police Impala and as usual they completely cut the entire wire harness under the dash on the passenger side. No audio, horn, nothing. I got the audio working and it’s been fine for month. I just got around to finding the tan wire for the horn and connected that. Everything works fine except when my left turn signal is on it pauses the radio?? Same thing when I apply the brakes. Doesn’t do it if I use my right turn signal. Also noticed that my left brake light will stay on for about a minute after I turn the car off. I’m convinced there’s some wires touching under the glove box because that’s the last thing I messed with before this started happening. I did nothing but connect the wire for the horn so I’m puzzled. I taped all the wires off that aren’t being used. I checked the fuses under the hood as well. I’m completely lost some body please lead me in the right direction.
I have a similar issue with my 07 police impala. The wiring under steering wheel is scary and there is also a viper alarm. Too many wires cut and modified for my experience level. Brake lights not working now and used to intermittently work when not being used and I'm pretty sure through research that an additional brake light toggle switch was installed for them to manually turn off the brake lights. This may be the same type scenario for you too. Under my console, I'm going to reinstall a toggle switch to two obvious wires leading from the brake switch and viper alarm that are disconnected. Fingers crossed as there are so many wiring mods under there. Good luck
Sent from my SM-G955U using Tapatalk
