2007 Impala SS
My 07 Impala SS Would not fire up out of the blue. It will crank but not start. After looking into it I found that the fuse to the fuel pump is not getting voltage. I switched out the relay and still not getting a response. If I use a jumper wire to bypass the relay then the fuel pump works. One thing I noticed is that the fuse has voltage for less than a second when you turn the ignition.
Has anyone had an issue like this or have an idea of what it could be?
