Hi. I'm new to this Forum and I would certainly appreciate your help in this matter. I have a 2007 Impala LT 3.5L (non-Flex), with about 190,000 miles. I have been running a K&N Air filter in it since about 70,000. I an attempt to increase the gas mileage, I cleaned the filter (I do this regularly), clean the MAF sensor using 91% Isopropyl Alchohol (I have never done this previously), and clean the Throttle body with STP Throttle Body cleaner. I did not remove the throttle body from the intake and manually opened and closed the valve. Every since then I have had issues with idle RPM. At first, it was idling between 1500 - 1800 when in park, and quite higher than normal when driving down the road as well. I unplugged the battery for several hours and then performed the Throttle Body re-learn procedure. That helped some, but it was still pretty high. I then removed the throttle body entirely and thoroughly cleaned it. I also removed the Throttle Position Sensor and cleaned it, though it was still very clean inside. I again preformed the re-learn procedure. My Idle in park is normal now (maybe a touch higher that before, about 750 now). When I shift into Drive or Reverse, with my foot on the brake, it stays normal. However, as soon as my speed increases just from rolling forward or backward the RPM jumps up to about 1,100 without me touching the accelerator pedal. If I do nothing but take my foot off the brake, the car will accelerate, on it's own, to about 35-40 MPH. even at 50-60 MPH, I feel like I barely have to touch the gas.
I read afterwards that you are not supposed to manually open and close the Throttle Body Valve. I figure I might have messed up the Throttle position sensor by doing so. I am hoping I did not screw up the Throttle Body itself.
I would greatly appreciate any assistance you might be able to provide in this matter.
Thank you,
Jon
Throttle Body Re-learn (3.5, 3.9 and 5.3 engines)
Per GM SI...
- Remove the air cleaner outlet duct.
- Inspect the throttle body bore and the throttle plate for deposits. You will need to open the throttle plate in order to inspect all surfaces. Do not insert any tools into the throttle body bore in order to avoid damage to the throttle valve plate.
- Clean the throttle body bore and the throttle plate using a clean shop towel with GM Top Engine Cleaner or an equivalent product.
- Install the air cleaner outlet duct.
- Perform the Throttle Learn Procedure.
Throttle learn procedure:
- Start and idle the engine in PARK for 3 minutes.
- The ECM will start to learn the new idle cells and Desired RPM should start to decrease.
- Ignition OFF for 60 seconds.
- After the 3 minute run time the engine should be idling normal.
I appreciate that, but as I stated I've already done the TB re-learn (several times in fact).
