Speedometer not working, tach is, does not show what gear you are in, step on gas and it is real sluggish, almost like it doesn’t want to move, reverse seems normal, engine light is on.....This just happened to the car, all at once, car has about 64k on it..... Any ideas?
Code is U0101. Speedometer has not been working, no gear indicator, seems to b stuck in overdrive... It’s been like this for a week......However, yesterday started car and everything worked fine, speedometer, and gear indicator working and car rides normal .......that lasted for 2 separate starts, then it went back to initial problems......Could it still b the TCM if the problem is intermittent??
