Hello!
I live in florida where it is about 95 degrees everyday here so my A/C is a must.
Today while driving my a/c was working fine one minute, then the next its blowing hot air. When i got to a light i turned the air off and then back on noticed the compressor wasnt kicking. I got home and noticed the air compressor fuse was blown. I replaced it and it then it worked fine for about another 2 minutes until it blew out again.
I then replaced the a/c compressor relay (the bigger fuse on top of the 10A fuse i replaced earlier) and it worked for a few minutes until the 10A fuse blew out again.
Has anyone had this problem? I dont want to think its the compressor going bad because if i replace the fuse it kicks right on.
Also i purchased an A/C charge kit because maybe the pressure is too low and MAYBE that is causing the fuse to keep blowing........BUT I CANT FIND THE LOW PRESSURE VALVE!!!
someone help!! lol THanks!!
