1 - 14 of 14 Posts
2005 Impala Stuck speedometer:
75 K, rides like it just came off the showroom floor - except for this one reoccurring problem.
I can reset the speedometer to 0 one of two ways: disconnect the battery or the 'secret' code, starting car in R 3+ times then starting in P or N ( the needle will fall completely to 0 or take several attempts.
Either way I can drive for 50+/- miles, sometimes a lot further, before the needle is stuck: says I'm driving 80 when I'm actually at 55.
No check engine light. The harness appears clean with no visible wire wear. I've scanned with my toy scanner and no codes appear.
Does anyone know of a code for this problem that may show up with a better scanner?
Stepper motors that operate the gauges are the problem. Search Impala stepper motor problems.
Discussion Starter #4
Hello Bill: I should have asked this earlier but it slipped my attention: Does a bad speed stepper motor ( speedometer needle stuck at speed higher than the car is going) affect the transmission performance or does it indicate a separate issue?
Discussion Starter • #4 2 h ago
My '05 had the same problem with the speedometer and it did not effect trans performance. I sent the cluster for a rebuild, replace all steppers. I't been several years but all the gauges still work perfectly. Sorry I can't remember where it was sent. If you rebuild your cluster the odometer will be correct. Junk yard replacement will have whatever mileage the donor car had.
Discussion Starter #8
If tranny shift points are affected, may suspect a faulty vss.
  • Transmission revs higher before it changes gears
  • The car's transmission engages into overdrive late and sometimes will never go into that top gear
  • Brakes are sometimes harder than normal when coasting
  • Speedometer behaves erratically or sometimes does not work at all
  • The check engine light comes on intermittently and sporadically when accelerating
  • The overdrive on/off light blinks on and on for no apparent reason
Other than the stuck speedometer none of the above apply. Also, the scan did not pick up code P0500. Thanks for the suggestion, the vss was one of the first suspicions I had but without the code showing up I'm looking elsewhere. If the transmission doesn't develop problems I'll probably leave as is and reset the speedometer to '0' when necessary
Discussion Starter #9
Thanks once again Bill. I think I'll keep a close eye and ear to the transmission; as long as I don't hear or feel anything suspicious I'll keep driving at 90 mph knowing full well I'm cruising at 55. At this time all the other steppers seems to be working fine.Appreciate your advice.
Discussion Starter #10
Hello Bill:
Well, slept on this repair and decided to order the part. Why not? At 71 there's always a few extra minutes to keep busy.
Hello Bill:
Personally I like having gauges that work. Not that hard to R&R the cluster anyway. Best of luck.
Discussion Starter #12
Hello Bill:
Replaced the stepper motor a couple days ago; works fine. Thanks for the suggestion. All that body contortion to replace a half-dollar size motor? I'm all for bringing back the speedometer cable ( I'm also a dinosaur )
I had the same problem! It started exactly like yours until eventually it stopped working, it's the stepper. There's a kit on Amazon for like 30 $gives you a couple steppers and the soldering iron.
Discussion Starter #14
Thanks Ozzie:
Already done. Took longer to take apart and reassemble the dash unit than the actual repair. By the way, included in the kit is a 'solder sucker', a tool I'd never used or heard of - but came in handy.
1 - 14 of 14 Posts
