My 2005 Chevy Impala 3.8L V6 stalls when coasting/braking at running temps. Car will only restart if https://pnrstatus.vip/I give it some gas. This is a reoccurring problem that seems to be worse in winter. Sometimes it goes a couple weeks without happening, Other times, like today, it stalled out 3 times in 20 minutes. Any help/ideas is appreciated. Thanks, https://sarkariresult.onl/
I would start by cleaning your MAF sensor. If it persists,replace it.I went to the junkyard last time & grabbed 2 of 'em.
I cleaned em both & the first one I tried worked like a charm. You should be cleaning that rascal with every air filter change. The debate will probably never end on whether or not you should use anything but MAF cleaner,and I have no doubt that the right contact cleaner is fine as well as anything that evaporates fairly quickly & doesn't leave any residue.
Just pay the $10 for the right sh*t and DO NOT TOUCH either one of those sensor modules with anything.
Page 1 of 3: How to Test the MAF Sensor (GM 3.8L V6 1996-2005). Common Symptoms of a BAD GM MAF Sensor. What tools do I need? Circuit Descriptions of the GM MAF Sensor Connector. How Does the MAF Sensor Work?
Page 2 of 3: How to Test the MAF Sensor (GM 3.8L V6 1996-2005). Testing the MAF Sensor Power (12 Volts) Circuit. Testing the MAF Sensor Ground Circuit. MAF Sensor Multimeter Test.
Page 3 of 3: Testing The MAF Signal With A Multimeter. 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005 3.8L GM. TEST 3: Testing The MAF Signal. Testing The MAF Sensor Signal With A Multimeter.
easyautodiagnostics.com
I hope that helps and solves your issue(s)
IOTM 8/14
Impala Forums
784.4K posts
61.5K members
Since 2007
