The heater is blowing air that is BARELY warm even after a 45 minute drive.
I have had the following done:
- waterpump replaced
- coolant flushed
- thermostat replaced
- various hoses replaced (I don't know which ones the shop changed)
Currently, the car (3.8L) seems to be in perfect working order except for the lack of heat. I had the above done a few months ago during the summer (because of a coolant leak causing the car to overheat) and never thought to check to see if the heater worked. I needed the heater today for the first time and got only luke warm air. The front and rear defrost systems are working, the A/C is working, the car is NOT overheating, and the thermostat appears to be working correctly. I am not getting a gargling noise like their is air in the radiator (a problem I have dealt with in the past). Any ideas?
- coolant flushed
