1 - 8 of 8 Posts
hey my wife has a 2004 impala and for the last 4-5 months sometimes the car will stall and sometimes it'll start right back up and other it won't even crank at all. At first i thought it could be the passlock sensor so I changed it out a few days ago, and it drove fine till today where it stalled at a light. It did start right back up. There were other times it would stall while driving and wouldn't even crank at all so i'm at a loss here. Any ideas??? bcm maybe? I kind of doubt bcm as when it stalls I dont see a security light, but I have seen it when it wouldn't crank.
Probably ignition switch, BCM won't keep the car from starting or running.
Did you just change the passlock sensor or the lock cylinder as well? Whenever you have a starting issue based on passlock the complete cylinder and ign switch should be replaced. All of these components can cause starting/stalling issues.
Do you have any dash lights on? If so, have codes scanned at a local autoparts store.
These ignition switches/cylinders are SUCH a common problem that I am getting sick of hearing about them
Edit: GM fails to issue a recall on this known problem. I would say at least half of all 00-05 impala's with over 100k miles have this problem which, most of the time ends up getting replaced by a GM dealer and costing over $300. These ign switches and cylinders tend to crap out at around 80-120k miles. Depending on use and cleanliness of course.
I haven't changed the lock cylinder just the passlock sensor from my impala that I know worked fine while it was in it. I guess that'll be my next stop the lock cylinder. I seriously doubt its the battery. No codes or any lights are on the dash. The last time it wouldn't crank I tried the 10 minute relearn and it still didn't crank, just happened to try again later on in the day and fired right up.
I would replace the ignition switch and the cylinder :eek:k3:
Happy to report I installed a rebuilt ignition switch along with passlock sensor over 2 weeks ago and so far so good no stalling or refusing to crank/turn over. Normally it would take a day or 2 before it would happen. Thanks for all the advice.
Back in Black
Thanks for the update
1 - 8 of 8 Posts
