I had a flat tire on my 2004 chevy impala. How do I get the message center to stop displaying low tire pressure (I already had the tire fixed)?
you will have to reset it using your radio if its the factory one, but i kinda forgot how to do it, I had a 2000 impala on 20inch rims and that thing use to allways go off. try turning off the radio, then hold the power button for 5 secs then a menu should come up on your radio.
Reset it through the radio controls. It shows in the manual. I think you need the key in the on postion and press and hold the tune knob. It will go to settings. There is another knob for scrolling through all the spots, but I forgot which one. Go to tire pressure. If you can't get it, send me an email. I'll look it up when my wife gets home with the car.
OK, if you're still watching, try this. Key on, radio off. Press tune / display knob for nearly 10 seconds. 'Settings' will show up. Press next ( above tune knob ) and scroll to tire pressure. Press preset 1 button. Radio says reset. Press display button.
Press prev button until 'exit' appears. Press display button. Done. Now wasn't that easy?
To reset it on a 2003 Impala LS Sport
Turn ignition to On but do not start the car
Pull the light switch out to the parking light position and push in.
Repeat this 3 times total
8o)
PS.
To reset the change oil light
Turn ignition to ON
Depress Gas Pedal to floor and release - do this 3 times.
