How do I get the low tire pressure alert to go away? I do not have a factory radio.
There should be something in your manual about that. Has something to do with removing the fuse and turning the ignition on in some sort of specific order.
Your valve stems are sensors and they transmit the pressure to the computer. If you are 2lb away from the proper level, it will turn on the light to warn you.
the reset proceedure is in the owners manual and you can call your dealership if you have missplaced it.
