I'm new to engine building and I want to drop a small block V8 into a '04 LS edition. What would they run? Good places to get one? What other modifications would have to made, if any, to the vehicle? I have found the 5.3L LS4 V8 from the '08 SS edition, would this fit?
Thanks
to do that swap you woud need engine, trans, pcm, harness, and someway to mod the exsisting pedal for the drive by wire TB.
Stock WBody SS's run between 14.3-13.9.
You would prob be better off doing a topswap (as long as its a 3.8) from an 00+ GTP or 04/05 SS. they run about the same stock, and w/ a cam, ported blower, IC, would put you low 13s or 12s, would be easier and cheaper that route.
Figure on a little over $1000 for the topswap, 300 fo rthe cam, another 500-1000 for the IC...
