ok... I want to replace the bulbs in our 2004 Impala LS
and can easily see & get to the outer white slide bracket.
But the inner slide bracket is hidden under a plastic baffle,
and can't quite get gain access to it.
The baffle is "screwed" in.... BUT - how to pull or remove the outer screw of the baffle to gain access to the headlight slider under it ???
Thought I would ask before I tried to pry the "screw" out and break it.
Can you get behind the light assembly's and pull the bulb socket from the housing? Many of the newer cars do not require the housings at least from the front of the car to be removed.
Unable to find the specifics from my Mitchell On Demand 5.8 regarding bulb changing.
Do you have a Chilton's Repair Manual for your car? It might have the directions you need for this.
