Seems to only happen when it's warm.
The main issue is pulling up to a red light for an extended period of time. Idle will be normal. Then it'll settle a bit to 5-600RPM. Idle air corrects normally. OR sometimes bump to 1000+ RPM>lurches forward before settling to normal. The odd time after idle correction it'll just stall out completely. Takes a couple tries to restart.
I parked in the driveway, in drive(daughter on the brake) Seemed to happen at the moment the A/C cycled on or off.
The only other symptom is, once rolling, if I hop on the throttle hard, it'll sputter for a moment between 2nd and 3rd then take right off like it should.
I've checked over everything I can think of. Cleaned and tested everything. MAP is good. TPS is good. Idle air valve was dirty, so just changed it. Seemed logical given the "idle" issue..
Any feedback would be awesome. A huge thankyou in advance.
