Odometer doesn't light up and you can't tell what it says. i got this car for my son a few months ago and have worked through several other problems. i went through all the fuses thinking it may solve other problems too and none are blown. Any help would be appreciated.
On the 03-07 Silverado pickups that's a symptom of cracked solder joints on some of the SMT resistors in the instrument cluster.
You can get them repaired.
I couldn't find anything specific to the odometer. I just remember when I replaced my dimmer/headlight switch, things lit up that I never knew had lights. I took it apart and the terminals were all gunked up. If the PRNDL above the odometer is dark, maybe just the bulb.
