2003 Impala cooling fans not coming on relays check out temp sensor replaced with an auto zone one and suggestion would help
Check the fuses, if ok then check for good power and ground at the cooling fan wire harness connector at the cooling fan. you can do this by connecting a test light between the cooling fan terminals, start the car and turn on the A/C. When the a/c is turned on the cooling fans are also turned on and the test light should light. If it does you need a new fan. If it doesn't you need to check the wiring for an open somewhere.
