Brake lights don't work. Third brake light works, changed bulbs, & fuse; nothing. Rear flashers don't work, either (front ones do). Running lights, directionals, back-up lights all work. What do I check next?
DIY section is not for questions, please post in the appropriate forum. Thread moved.
Have you checked the 4 way switch? I'm not an expert but I know if you don't have a 4 way switch you wont any brake/signal lights, learned that from a personal experience...
This is indeed true and probably the problem. The turn signal power comes off of the hazard switch. Common failure on these. Simple and cheap fix. Most people state you have to remove the dash to replace but, this is infact not true. Instructions below
Chevy Impala Turn Signal Switch Replacement - a set on Flickr
