ive got a 2001 impala and depending on how big your stereo is, i ran 1/0 gauge under the car in eletrical conduet, much much easier than trying to find a place to run wire, but im not positive, but you might be able to sneak it where the steering wheel column goes through the firewall, there might be a hole to the bottom left of it behind your carpet, but im not sure, it looks like a astrix * just poke a screw driver through there and run the wire through that, (it helps if you jack the car up and get it from underneith), but if that holes not there, im not sure, im check on mine and get back to you
