When I try to turn my wheels to the left it feels like I have no power steering, this only happens when I slow down or I'm stopped. When I press on the gas I can turn the wheel to the left with no problem.
It does not happen at all when I turn to the right.
one of several things could be wrong......could be a tie rod seizing up ( although that usually affects steering both ways....could be a bad rack and pinion gear....or....it could be the steering knuckle on the steering wheel shaft....chevy had some problems with them back in 03......you can check with your local dealer to see if your car was part of that service bulletin!!
