It does fine when I first start it, after a while, especially as the day goes on and it gets hotter, it has trouble accelerating... It sounds like it's grinding.. once it passes 65 it's fine... The air conditioner also died... My mechanic can't find what's wrong; he says the transmission and the gas systems are fine; he hooked it up to that machine but the machine says the car is fine. At times when I'm stepping on the gas trying to get it to go, the check engine like turns on and stays steady, but next time I drive the car, it's off. It is due for an oil change and the change oil lights up, but my mechanic saw that and he didn't mention that was it.. Please help.. anyone?!?!
I'm thinking of trading it in even though I know i'll have negative equity w/ the trade in. =(
it's got 93k miles
Mysteriously sounds like an EGR valve not seating properly when hot. No stored codes? Take belt off from AC compressor if you don't want to spend the dough to fix it! How many miles on this engine? Need a tad more info! Good Luck! ;-)=
