I need to replace a wrecked driver side door on a 2002 Chevy impala. Will other driver side doors from the eighth generation impalas fit a 2002 impala?
The basic sheet metal, glass, hinges, etc should be the same from 2000-2005.
You may get to play swaptronics by moving the old door harness to the new door because of pinout variances or your original door switches don't match the harness in the new door or the new door has electrical options that aren't on your rig or the other way around.
You may want to move trim like your correct color door card and the window welting with the black or chrome or without either so it matches your car.
The mounting/routing holes are there... just move the guts and trim from your door to the new one and drive.
Reactions: plano-doug
