I've seen this posted before, but it has me baffled. I started this car about 10 days ago and it ran fine for a few minutes. Turned it off to clean up and get it off of jacks and it hasn't started since. Jump didn't work. I did notice the positive battery terminal bolt was stripped so I replaced it. Also noticed that I couldn't tighten that bolt all the way. Negative was fine, but positive was slipping. Replaced battery. Same issue. Removed red rubber sleeve and cleaned the contacts as much as I could, yet I still couldn't get the bolt to tighten completely, even without the rubber sleeve. It seemed to have good contact anyway so when I still couldn't start it, I replaced the starter. Same issue.
So, this cable MAY be the source of my problems and I've got to replace it, but I'm still confused why the bolt won't tighten completely. It will tighten without the cable, but not with it.
Any ideas?
Any ideas?
