Does your Pontiac sometimes have the ABS and Track OFF light come on ? I think there is a wire loose somewhere... Sometimes it comes on and sometimes it doesn't. Any suggestions?
I have done the reseting option already and it keeps happening. Any else that comes to mind?
it is possible that you have an intermittent fault in a wheel speed sensor. this is a fairly common problem for 97-02 fwd gm passenger vehicles with wheel speed sensors integrated in the hub assembly. the dealer should be able to pull abs codes, and if the abs and track off light have been on recently a tcs diagnostic code will usually be stored. i have seen faulty wheel speed sensors frequently in these vehicles.
Have the brakes serviced for the abs lite as for the track lite that happens from to time to time. You may need to just reset the computer
