1 - 9 of 9 Posts
Hi everyone,
I just bought a 2001 Chevy impala (3.8L) with 56k miles and knocking coming from the engine. I got a great deal and assumed that in the worst case scenario I will need to change the engine.
After listening to the car I started googling and found a youtube clip with what seems to be the same sound. You can fast forward to 48 seconds into the video. It is not my video btw:
What do you guys think it is/could be? If it is a rod knock, would you drive it home 25 miles? Could a rod knock be fixed without taking the engine out?
Thanks in advance,
Andy
sounds like a spun bearing and the piston hitting the head. engine would have to be taken out. if theres enough damage might as well replace the engine
and i wouldnt drive it at all unless your planning on replaceing the engine, i had a s15 that spun a bearing and i didnt make it 2 miles before it cracked the head
Sounds like the flywheel is cracked to me.
for the record, it was a rod. I did turn the car on and drive it for about a half mile and the car eventually stalled. When I went to turn it back on I think I put the rod through my oil pan. Noise followed by flowing oil
56k miles and a rod goes through the pan? Ouch sounds like someone didn't take care of it.
Wow, had the oil ever been changed before you bought it?
The car belonged to a local police department. They have mechanics on staff and I suspect that they change the oil regularly but I can't be sure. I didn't ask for maintenance records but I'm sure I wouldn't have gotten them even if I asked.
Well, it doesn't matter now anyway, but engines with regular oil changes don't usually have that problem.
:crybaby2: sorry to hear this man
1 - 9 of 9 Posts
