2000 Impala- Lost Brake, signal, and hazard lights. Lost signal sounds and signal lights on dash.
What has happened here?
Update 15a fuse blown for turn signal. Replaced and it blew again. Put in 20a, signals now work fine..But no brake lights or hazards.
Thank you.
This sounds like it has a few elements of a problem I ran into years ago. Replace the hazard switch. There is a trick to doing it the easy way. I did it doing something like is in this you tube video.
I think it will fix your brake light problem and any turn signal issues. I did not have the blown fuse problem, but there is enough of it that is similar, I think it all might be coming from that hazard light switch.
