1 - 20 of 40 Posts
· OEM LOL
Title sums it up my oil smells like 2 stroke mix and not just a hint of it like knock your socks off 32 or 50 to 1 smelling mix.
And my mpg sucks balls compared to most other people i mean i drive hard but normalish driving around town at like 13mpg and 18mpg on highway. According to the good old computer
Uhh i use synthetic 5w30 and k&n oil filters
Change oil every 3-4k
No out of ordinary engine noises
Maybe a little decrease in performance (hp)
Dont really see any leaks i pressure wash the engine and engine bay once a week to 2 weeks
No smoke out the exhaust pipe
(im not here to argue or justify the use of synthetic oil or k&n oil filters but if it could be the problem let me know)
Anyone know what it could be?
Thanks you guys are the best!
· 8th Gen Antagonist
2 possibilities come to mind, 1 is the fuel pump could be overpressurizing and forcing gas into the oil. 2 is your head gaskets.
What it boils down to is, if the oil smells like it has fuel in it, it probably does. That is going to be extremely hard on bearings, so at the very least you'll want to change it ASAP. Synthetic oil or K&N filter are not the cause, nor could anyone ever logically justify any way they could be. My only beefs with those are, synthetic oil is completely unnecessary in non-racing applications, and K&N filters only flow better by filtering less. Neither of those can be the issue you are having.
· OEM LOL
last time i blew a head gasket was on my supra and i dont remember the coolant and oil mixed smelling like this? all i remember was spark plugs 3,4,5,6 sitting in coolant and the thing bogging around sounding like a worked subaru.
· OEM LOL
Discussion Starter · #9 ·
yeah i pressure wash the thing often its definitely a big leak not just seepage.
fml i got a trans slipping nuts sack and a blown head gasket and i still think either a injector is sticking of something cause there is def. gas in that oil along with coolant proably. F*ck i hate this car. i had less problems with a 30+psi jap motor.
· OEM LOL
Discussion Starter · #11 ·
Me either i guess thats what you get for buying american.
whatever, but this is definitly the head gasket right guys?
When i do the head gasket im gonna pull the fuel rails and cycle the car and make sure they arent sticking at all and replace the o rings on them i dont really know whatelse to do.
A bad cam position sensor could cause this also but i dont have any check engine codes other than crank position sensor from my new computer from overkill which i never got that relearned can that be causing this? i doubt it but maybe someone knows something about it that i don't?
But the oil doesnt appear to be milky or have milky ring on the cap, no fluid coming out the exhaust, no sweet smell, no smoke, heat doesnt smell sweet, no red tint on the spark plugs.
but i am losing coolant about a quart over 3 weeks but i did fill the overflow way up for winter to work out any and all air and get really good heat in the thing so maybe the overflow overflowed and thats where it went if that is possible.
i guess i am just brainstorming here feel free to pick my brain guys.
· Premium Member
· OEM LOL
Discussion Starter · #16 ·
The good news is if its not just the headgasket to solve the problem and something is warped or shot in the motor (which i highly doubt) its getting procharged or turbo'd and manual swapped. so that would be an interesting project.
· OEM LOL
Discussion Starter · #18 · (Edited)
Either this motor bored and stroked out to a 4.0l with a remote twin turbo setup or a pro charger.
Or a 3800 with a turbo or a ported supercharger.
Accomplished quiet easy as far as swaps go iv done harder. Dont know why it compares to a ls9 and rwd.
All id be looking for is 350hp to the front wheels
Plus i got my 98 lincoln markviii to drive around till i fix the impala. 400hp worth of ford ponies:devil:
· Premium Member
My ex's minivan was losing antifreeze too. It wasn't a lot, and there was no sign of its leaking or burning. We had the intake gasket fixed and that cured it. I know its a different engine, and different year, but the symptom is the same....?
1 - 20 of 40 Posts
