where does the vacuum hose off the optispark go to.
it was a vent on the earlier models of the lt-1. starting in 95 or 96 they ran a vacuum hose to them to remove moisture.
Good question, it should just plug into the intake somewhere. But, I not sure where it needs to be exactly.
Here's a few links where you may be able to find the info and alot more.
Good luck!
Nowhere, Its A Vent
Hmm....it is a form of a vent but they are connected to the INTAKE MANIFOLD on the driver side. Inline (in between one of the 2 rubber opti hoses) there is a blue check valve/diaphram. So to make a long story short, 2 lines from the earlier opti sparks, one goes to the intake boot on top with a blue angle plug.....and the second line goes directly into the driver side on the intake manifold.....thats the line that has the blue check valve in it.
