getting a p102 code ,? changed maf sensor o2 sensor plugs, plug wires , coil pack , tps sensor , checked fuel pressure its good, checked vaccum for leaks none found, car does not have to be in gear to have te problem
this code is for the maf or mass air flow sensor,did you reset the computer after you changed it? pull the positive cable off the battery let it sit for 5-10 minutes then reconnect this will clear your saved codes
