Hey Guys and Gals, i was cleaning up the ss the past weekend and as im letting it run for a little while as im cleaning it up. All of the sudden it cuts off by itself. It crank right back up, then i cut it off till after i got done cleaning it up. it fired right back up again. I thought nothing of it. a few hours later i tried to crank it, it wouldnt, so i new i had a problem. it just spinned over, i changed the coil and the coil ignition module but still nothing. Could someone help me out on what it could be,thanks
Are you getting fuel to the engine? Check the fuel pump flow and fuel pump fuse and things like that. Is the check engine light on?
check engine light is on and the check gauges light is on. just shot some starter fluid and tried to crank, still nothing.
