when attaching to the back of the compressor which way do the gasket/seals go on? it came with three.
this is for air conditioning
2 of the seals will go on the line where it bolts to the back of the compressor, the other one should go on the low side line( which is the larger of the two lines) and where it attatches to the accumulator, I'd think there should be a 4th seal for the high side line( smaller line) which attatches to the condensor. Make sure you vacume the system for at least an hr before you charge it.
