1 - 14 of 14 Posts
Hey All, hoping someone out there can help me find a class 3 hitch with the 500/5000 lbs tonue/trailer weight the wagon is rated for. All my onlien searches come up with nothing but the 350/3500 hitches which my car already has. I want to pull the existing one off because the hitch is a single unit that does not allow me to remove the hitch so it protrudes past the bumber and it will not be long before bloody shins arise.
Since I will take it off, I figured upgrading to the larger one would be a good idea, but I CANNOT FIND ONE. Anyone out there know where to get one? Dealers used to install the 5K hitch, so why are they not around anymore?
Yeah, I saw that but do not want all the extra crap attachements to make ti work...there was once a 5K hitch that did not require the weight distribution. All the GM 1500 vans and trucks had and can still get them, but the B-body is difficult at best to find.
I feel ya...
I've been looking for a big hitch, too. I have a bunch of 2" reciever stuff, and there is no way I'm downgrading to the 1 1/4". I'd like to get a small camper soon and use the wagon for road trips. I can find 9,000 lb, 2" recievers for sedans, I've thought about buying one to see what I have to mod to make it work.
The sedan and wagon hitches are QUITE different.
The wagon Hitches are no longer made, so it would have to be an old stocked one.
if you havent found one yet then i am taking mine off. it is a 2" reciever. i havent got under there to make sure it isnt welded but i will check it out tomorrow and let you know.
Sorry to bump an old thread...
The problem here is not the actual hitch but your car. Any of those class 3 hitches would probably work but most will not go against the car manufacturer's recommendation.
Way back when I had my '91 Caprice wagon, I bought a Putnam hitch that was a huge thing and rated for 7500 lbs, but no way could I safely tow that much. The limitation is the (lack of) total vehicle weight and the rear suspension of our cars. A weight-distributing hitch helps your car tow more.
If you really need to tow that much regularly, consider a larger vehicle (truck). You could probably get away with towing that occasionally, but bad weather, hills, etc., could end up with bad results.
I'm new to the forums, hate to bring up an older thread. But, what does the factory tow package add on a 91 caprice wagon?
Try this:
What exactly does the "Towing package" on the LT1s consist of?
My OCC has factory air leveling in the back, but I have no plans to haul my camper with it until I get the transmission gone-through and beefed up, and that's when I'll add an external trans cooler. The weight-distributing capability of the big factory hitch is the biggest factor for me, as it will greatly improve handing when towing a heavy trailer.
A lot of people think you need a truck to pull a camper, but that simply is not true. People pulled campers with big cars for decades until Trucks and SUVs became hip, and these wagons were intentionally built for heavy-duty service. It was a dying concept by the early 90s, thus these wagons were among the last of such vehicles built with this kind of capability. I believe the longevity of these cars is directly attributable to their over-built nature.
1 - 14 of 14 Posts
