1 - 12 of 12 Posts
So the basics:
350 5.7L engine, 191k miles.
I was driving to work and the car started overheating, it got up to about 260 degrees.
Now, I'm not sure what it could be. Here is what I know and what I've done:
  1. Replaced the thermastat a couple of months ago when it went out with a new one that is designed to break in the open position.
  2. Did a coolant flush 8-9 months ago, so I don't think it could be that.
  3. The car wasn't from what I could tell leaking any fluid except the steam/condensation buildup from the cap.
So what could it be? When a water pump goes out wouldn't the pulley lockup and eventually wearout or make the belt squeal? Or is there more than one way a water pump can stop working. The only way I know that pumps go out is when the bearings wear out and it gets stuck.
Also my thermastat has went out twice before and it usually starts leaking around the seal and it never gets that hot... usually just above operating temp.
Any suggestions?
Were you stopped or moving slow when it overheated? That would be a fan problem. Was the coolant boiling in the overflow tank?
i have the same problem. just started today. 95 with LT1. i was sitting at the light and it cut off. i started it and pulled over and the coolant was boiling out of the reservoir. i just bought this car last week, but it looks like clean coolant. also the guy b4 me installed radiator fans, but only 1 works. do i just need 2 powerful electric fans?
The Unscrupulous Lt. Colonel
And for a good portion of the time, only one "will" work. That being the passenger side fan. Thats the primary fan and does most of the work. If you are concerned about the fans, turn the car on. Pull the temp sensor thats on the right corner of the water pump, and both fans should come on.
Also, go ahead and change the thermostat when you get a chance. Thats usually the problem sometimes with overheating issues...
if u have clutch fan it could be that,one way to check is at norm temp watch the fan and have someone turn motor off, fan should maybe 2-3 turns and stop, if more its fubar
Had the same problem with my 5.0L 1992. It only cost me $12 to fix the problem and you already have the tool to fix it. It's your Coolant Temp Sensor, and its the same size as your lug nut wrench with your spare. $10 for the part and $2 for teflon tape and 45 seconds later, fixed. Hope this helps
I love when noobs think they have the answer with such incomplete information.
i am gonna give it a try..
for some reason when i bought the car, the last guy rigged the fan to the fuse box so it is on with the key
First thing to do is wire it back the way it's supposed to be, then figure out the real problem.
The main problem is a blunder from GM ! the hot return tube from the inside heater is connected to the 'cold' side of the radiator !! move itover to the 'Hot side where the hot water from the engine comes in ( that's driver's side upper tube ) by means of a 3/4 T piece with a pilar entree of 20mm for the heatercore tube ..problemsolved if the rest of your system isclean ( flush with sodacrystals several times till clean clean clean
In moving the insideheater return tube tothe 'hot ' side of the radiator you are going down on engine temp by 5 to 10 Celsius on the system and you still have a heater functioning .
1 - 12 of 12 Posts
