Guest
·When my son pours gasoline on the carb the Caprice will start up and idle until the gas is used up from the carb. The fuel pump, fuel filter, strainer, relay, battery are all new. Distributor is fine.When he pulled the fuel line from the filter there wasn't any gas coming out. The pump isn't able to pump gas for some reason? We've checked the wires/cables and general area all around the pump. Everything is checking out alright as far as the power. Any suggestions? Thank you
I'm sorry. I don't know if they checked for clogs. How does a person do that?
He can't hear the pump running at all. Where do we locate the oil pressure sensor? Thank you
