undo the bolts holding the filler neck to the body, put a jack under the tank, and undo the straps holding the tank up. Lower the jack (slowly/support it) and just do it that way. Pretty self-explanatory from their. Installation is reverse. The take should be plastic, as are some of the fuel line connectors. Change the strainer too while you are at it. Best done with little/no gas.
