My dash lights are not working. Not sure where to start testing. I dont think it is the bulb because they used to work fine and my interior dome light also worked fine. Now neither of them work. Is there a way to test the connection where the fuse plugs in, I have replaced the fuse even though it looked fine and it did not help. My headlights work so I am thinking the switch is fine. Not sure where to go from here.
Did you rotate your switch to adjust dim to bright and dome light on... If so check grounds on switch and under dome light cover...Also your switch could have burnt or bad contacts
All door switches work?
