its a pretty hard job to do, i have restored a few of those cars and always lifted the body from the frame to do it,you have to have a method of getting the body away from the frame and rolling the fame out from under it,once this is done you have to make sure the body is blocked up real good,the use of a sling is real handy when doing this,be careful if the body weight shifts it will fall down you,have several people around to help when doing this don't attempt doing it alone,a home made sling can be rigged to use for doing this,good luck.
