I am toying with the idea of rebuilding the stock motor in my '63 Impala SS. Does anyone have any advice as far as a direction to go in regarding performance on a budget? I am looking to do the work myself, so that will be a savings, but as far as defining what gets upgraded (cam, pistons, heads, intake, carb, etc) and what to upgrade to (how much to bore over, makes, models, specs) I am looking for help in this area. The overall goal for me is improved performance.
Also....as I said, the car is a 283ci car with a Powerglide 2 speed automatic transmission. From a stop in 2nd gear (Drive), it seems a bit sluggish, but then again it's almost 50 years old. If I start out in 1st gear and punch it, it gets up and goes, but it's still lacking power. In either gear, once I get up to about 25-30 miles per hour, it has no issues at all. Is this just a product of a relatively small motor in a 3,500 lb car with a two speed tranny? I've read a bit about how the small block chevy in general is a good motor and has alot of options as far as tuning and and aftermarket performance products, which is why I'm thinking it might be time to do a rebuild and upgrade some key items.
Any help would be appreciated, and once I start the build, pics will be posted,
