Hey guys I’m hoping someone can help me here. I’m trying to put my 61 impala 4dr sedan back together, but I can’t for the life of me figure out how the rear window regulators get installed with the glass. No matter how I line it up, the roller is in the way of where the screw is supposed to be. Anyone have any ideas here? Repair manual is no help
163066
If you crank the mechanism up and down, look at all the different available holes that you can sneak your screw driver through. I took one apart not that long ago and didn't have any problems.
It doesn’t matter what hole you line it up with, that roller is always blocking the screw
Discussion Starter #4
I found that if I screw the track on one side at an angle, with the other little piece of track on the door not installed you can slide it down the rollers as you install the window. and then push the track back into place and get your other screw in
163068
