I have a 2008 Chevy Impala (50th Anniversary edition) and there are times when the service engine light will come on and the dash will say tighten gas cap. So I tighten the gas cap and the light stays on. I know it's not the gas cap (which I have replaced) because it's tight. Is there a sensor or air vent that is getting dirty?
Thanks
Mark
There is an EVAP canister vent solenoid behind the filler neck, take it out, clean it up, and lube it.
Reactions: cabowabodude
Thanks
Mark
When you say that you've replaced the gas cap, what did you replace it with? Did you go to a auto store? You need to go to the dealer, supply your VIN, and get the EXACT gas cap for it.
Source: Spent $800 replacing valves and sensors only to realize the gas cap I bought from the Auto store was bullshit.
I replaced my gas cap with a locking gas cap from Canadian Tire, so that no one can suck out my precious fuel. It works fine, but a couple of times I got that 'gas cap loose' message and it was because the cap wasn't locking properly. I think it needed lubricating, but it works fine now.
