I'm in process of doing to afm to non-afm conversion on the 2007 3.9l in an old police car. While I have the engine out are there any sensors I should go ahead and replace?
The kit comes with the cam sensor which I'll have to relearn. I have the coolant temp sensor out of the head since I have the heads off to work on and will replace that one too.
Currently lapping the valves and replacing the seals. I got all new pushrods and a full set of non afm lifters. Cleaned up what little gunk existed in the pan. All new seals, rear main and crank seals. Timing chain, sprocket and tensioner new too.
This filter was in the kit, listed as the VVT Spool Filter... where the heck does it go??
