Guest
·My 2005 Impala with 3.8 V6 and automatic with floor shifter suddenly won't shift into PARK....I shifted out of PARK normally when started car this morning and now it only goes up as far as R....acts like it is being blocked from going into PARK....Had no previous warning of a problem...I thought that it was the little release button on the shifter knob, but it works properly when trying to downshift manually to a lower gear than OD...It won't downshift manually from OD to 3 unless I press the button, and it works properly that way....Does the brake/ Park interlock safety switch also prevent the car from going into PARK if the switch goes bad? Car has 66,000 miles with a floor shift..not a column shift... I have had to resort to parking the car in neutral with parking brake applied and then removing the positive cable from battery..as I've noticed that even with key off in neutral, I am getting a draw on the battery as my battery idiot light will remain lit in neutral....
