we recently received a gift, a nice '03 Impala for my kids, but it has severely fogged headlights. I've seen wipe on chemicals to fix that - anyone ever try that? The headlights work, and should pass inspection, but it just looks nasty. my kids could care less but if I can spend their money to fix it up ... why not!
don't have an actual pic, but this appears to be a close match to the vehicle
Likely the oxidation the builds up on virtually every stock 7th gen headlight.
Honestly, your best bet is to wet sand the lenses with fine grit sand paper (finish with 2000 grit) and then buff and polish the lens using the appropriate compound to restore the shine. Good luck!
wonder why that photo I uploaded yesterday doesn't show. maybe it's better to add a link from photobucket or something? I just uploaded it again so maybe there was an issue ...
photo stuff ... weird
finally took possession of the car, got it inspected and got the snows mounted - ready for snowpocalypse 2014
ob closer inspection of the headlights it looks like they are in fact foggy on the inside. I need to look again in daylight if the outside is an issue as well, it may not be, it might just be a issue with the inside fogging
No way to really fix it, if you sand and buff them out. Then you are only delaying the process, you can find brand new headlights for around $80 on amazon. Since the headlight restore kits are around $40 I think it woukd be a wise choice just to start over with new. My headlights are so far gone that I could sand and buff all day long and it wont make a bit of a difference.
No way to wily fix it, if you sand and buff them out. Then you are only delaying the process, you can find brand new headlights for around $80 on amazon. Since the headlight restore kits are around $40 I think it woukd be a wise choice just to start over with new. My headlights are so far gone that I could sand and buff all day long and it wont make a bit of a difference.
This is true. Its MUCH easier and will look much better than sanding/buffing. It depends on how far gone the lights are as to whether it would be worth it or not to buy new ones or sand/buff.
I wet sanded my last impalas heads and it helped some but it was pretty much on the inside. Outside was really smooth but still a lot of fog, not from water. it looks like its been etched more or less. I'm just gonna buy new lights and dogs.
any opinions on replacing stock bulbs with something brighter? I was out the other night in the rain and was thinking it would be neat for better lighting in general
The headlights you linked aren't going to make the headlights brighter. It will give you a slightly better beam pattern, but not worth the extra $100 IMO
gonna load some pics. I think the 1st step would be replacing the plastic headlight housings. they are pretty nasty. more than just moisture fogging inside. I did a small experiment in a small area with a small dab of toothpaste and a magic eraser type sponge and it didn't make any improvement
before I can slide up the headlamp fasteners there's a black cover in front near the hood latch and it covers the inboard fastener on each side. it looks like it's held on with just 4 fasteners/clips but before I start yanking does anyone know the proper way to remove this clip/pin? can I lust lever it out with a thin screwdriver head?
Thats how I've always done it. Pull the inner part out, then pull the whole plug out of the hole. Lift the back of the cover (where the plugs were) up, and then push towards the engine, it will come right out
I found this one and it has good reviews as opposed to 2 others I found. the only thing is I'm not I like the darkened look. but that might be what the original was. your thoughts?
I'm a little late, but a trick I learned is taking a clean dry cloth and some mint toothpaste and run it into the headlight fun a circular motion for a few minutes. Then wipe it off with a damp rag.
From that one picture, his headlights really look "pitted" (just like a windshield can get pitted over the years), so I don't think that there was any way to save them...
The toothpaste method sounds like an interesting way to remove some basic "hazing" though. It's amazing how many different uses regular old toothpaste has!
Impala Forums
784.4K posts
61.7K members
Since 2007
