need to replace all componant? i hit a curb and now the back tire is pushed back some and i went to a frame shope and they said that i need to replace all the stuff that is the back tire hub and baring everyhing is that what i need to do cause i dont know nothing about cars so if someone can help i would really appreciate it
well if you bent sum of the suspension you will have to replace the sus. components to make the alighnment correct
if your tire is back thats called setback, you have sever damage to suspension and or frame, i would go with what they said, you most likely bent a trialing arm or your a-arms. if you have ind. rear suspension, then you most likely need that side replaced, if you have a straight axel you could off bent axel out of align and dmaaged track bar. im sure what they are telling you seems accurate, but if your worried never hurts to get a second opinion, also shop around you could get a better deal.
