02 Impala LS, 3800 Series II, 112K miles, well maintained. The vehicle started yesterday as it always has, it was started last at 9:00 P.M. last night, 9 hours later a turn of the key gives no results. The battery is fully charged, all the accy come on, headlight are bright, battery reads fully charged. There is no clicking when the key is turned into the start position. The check engine light remains on when the key is held in the start position..I believe this is a common light process, not for sure though.
Any help is greatly appreciated. Thank you in advance.
Could be many things. Starter relay, starter solenoid, key switch,etc. It is strange that you have had no problems before.
Could be one of two things. Could easily be your starter relay gone bad. Or there could be a short in the electrical components of your key switch. Have the column checked out and inspected for any signs of normal wear and tear. Good luck!
