so the original problem was that the fans made a horrible noise on start up ended up being a bearing in the pass/side fan. after all that was replaced i realized that the reason that the bearing went out was because the fans stayed on too long after the car was off sometime up to 10 min after only driving about 5 miles or so.. my thought was that the coolant temp sensor was out so only being about 12$ i replaced that. the fans still run so i tried a new engine fan relay. same thing they keep running about 3-5 min. after the car is off only from starting and stopping the engine once it was cool.. im confused please help
