Guest
·...burning. Previous clog evap fixed I have been having intermittent problems with the hvac (passenger cabin) fan. The issue first started when running the A/C in the summer, while steering the fan would make a squealing sound. Around the same time the A/C was dripping water on the passenger floor. I had the shop fix the while the car was in for inspection (clogged drain line) and I replaced the passenger cabin air filter at the same time.
Shortly after the A/C dripping was fixed the squealing of the fan started to happen more frequently and not just when I was steering. The one day while the fan was on low speed and the climate control set to vent I smelled an electrical burning smell coming out of the vents. I turned off the fan for the remainder of the drive. When I tried to turn the fan on later Speed 1 (what the fan was set to when the burning smell came out) did not work. However speeds 2-5 worked ok. Soon though the burning smell came back and all speeds of the fan ceased to work.
