If you are having dash lights come on randomly such as the AirBag, ABS, Trac OFF, Service Trac Control, or Brake lights come on PLEASE READ or DO YOUR RESEARCH. These model cars have common Ignition Switch, BCM, and EBCM issues. Dont let this turn you away from these cars as simple maint and repairs will prevent further damage! A simple failing ignition switch can cause major issues! So, personally I recommend that if you own or plan to own one of these vehicles you have the ignition switch and electrical system tested by a dealer right away. If the dealer or you have any hint that the ignition switch is failing get it replaced, ASAP. If you are willing and have the skills to replace it by yourself you will save atleast 50%. Most shops/dealers charge $200-250 for an ign switch when you can get one for a third of the price. After it is replaced I RECOMMEND blowing into the key slot on the ign with an aircompressor or compressed air atleast twice a year to keep dust, dirt, and grime out.
I hope this helps some people and prevents further headache's
k3:
